I have fitted a "new" alternator to my brothers lightweight with a 2.25 diesel engine. Previously it had a alty from a Nissan of some sort. But I wasn't having much luck finding one so have aquired and fitted a Vauxhall one from a 1.7D engine.
So everything is fitted and it looks ok but I can't work out what should plug to what. Previously there was only a positive and an earth.
The new alternator has 3 wires going to a multiconnector, green, black and yellow. And a screw terminal on the back.
With nothing connected I measured the voltage at each terminal and they all read 0V except one which reads about 0.5V.
I suspect it will need a battery connection to start charging but don't want to start plug stuff in in case i break it.
Here are some pictures I would appreciate any thoughts!
Single terminal on the back
