Post by Zelandeth » Fri Feb 06, 2015 7:25 pm
Finally found the mirror that I bought about eight months ago for the C5 and fitted it. Makes life a lot easier, as it's actually quite awkward to look right over your shoulder while riding it. Just normal blind spot check now which is far easier on the back and neck, and less likely to send me careering into the nearest streetlight, bin, bollard or parked car while trying to look backwards.
Folds down pretty much flat with the bar too, so won't get snapped off when in the garage hopefully. ...Cost all of four quid anyway, so no biggie even if it doesn't last long. Doesn't seem to vibrate too much and holds its adjustment just fine it seems too from the brief trip out today.
Also found an old wired cycle computer in one of my boxes of bits which I will probably fit tomorrow. The current wireless one is about as much use as a chocolate teapot. It looses comms with the pickup half the time, and the battery seems to last on average about three and a half nanoseconds. It's also got a capacitive button to change modes, which activates randomly when it's either slightly damp or slightly staticy on a dry day. Hopefully using something a bit lower tech will solve this problem.
Oh...also when we had the snow, I answered the question of whether you can in fact do donuts in a C5, the answer is that yes, you can.
Ged
Post by Ged » Fri Feb 06, 2015 11:54 pm
i used to look after this...
and there were two C5`s just lying around in one of the ballrooms.
yes, you can do donuts.
and drift.....
Post by excossack » Sat Feb 07, 2015 9:17 am
Camell Lairds?
Ged
Post by Ged » Sat Feb 07, 2015 9:57 am
dunno, stock pic.
it was at the pier head when i was there
Post by Zelandeth » Sun Feb 08, 2015 7:02 pm
Met up with a fellow collector of all things lighting related who was having a clear out. Aim was to pick up four Philips MA90 street light heads which will be used to sort out a couple of black holes out the back of our place, making it all usable in the evenings. Will be handy come the summer when we tend to have barbecue parties etc. Area round the house is pretty well lit, but there are a few areas which are pitch dark presently, these will sort it nicely.
...Unsurprisingly given he's having a clear out, he turned up with a fair amount more than I'd asked for. This was the back of my car before I started unpacking.
It's all actually stuff I have practical use for...just means that in the short term it's added another couple of layers to the Tetris puzzle that is the garage!
Post by Zelandeth » Sat Feb 14, 2015 4:33 pm
Changed the front spheres on the Xantia. Isn't it wonderful when a job you have not done in over ten years is actually as easy as you remember. Six minutes start to finish. Exercising the suspension after the work took longer than the job itself.
Goodness what a difference. Like a totally different car.
Ged
Post by Ged » Sun Feb 15, 2015 9:32 pm
sat watching this out of the window.
http://www.liverpoolecho.co.uk/news/liv ... rs-8649370
:roll:
Ged
Post by Ged » Sun Feb 15, 2015 10:36 pm
spend all day playing COD, then dont understand why the real shotgun doesnt have auto aim :lol:
Post by excossack » Wed Feb 18, 2015 6:36 pm
Saved this from the skip - 1940s Bush valve radio
Post by Zelandeth » Fri Feb 20, 2015 8:58 pm
Ooooh....Right up my street. Bush AC11 if I'm not mistaken.
Restored one of those for someone a couple of years ago, really nice easy set to work on. Think I still have one of my own...not sure whether it made the move down here or if it's still up at my parent's place. Would need to go and rummage in the garage to check as most of my vintage tech is tucked away at the back of it (it's a bone dry integral garage, so no worries about things going rusty etc...it's drier than most houses/flats I've lived in!). Should perform well with relatively little work.
If you plan on restoring it, full service data is available for a couple of quid from www.vintage-radio.net.
You used to working on kit like this, or new to the field?
Post by excossack » Sun Feb 22, 2015 8:44 am
It is indeed a Bush AC11.
Never worked on kit to like this and not sure what I am going to do with it other than save it from the skip.
Cheers for the link, I shall have a look.
Post by Neil Chowney » Sun Feb 22, 2015 11:48 am
...spotted a weasel legging it across the rocks by the ponds.....
Post by Zelandeth » Sun Feb 22, 2015 8:13 pm
AC11 isn't a bad set to start on to be honest. There's a "where to start guide" somewhere over there as I recall. Only thing to remember is that throughout the set that high voltages are present and that they can bite.
If you decide to pass the set on sure someone will be happy to give it a home. Sadly they aren't worth much (probably because they are pretty bulky things and that the market is pretty saturated).
Ged
Post by Ged » Tue Feb 24, 2015 12:47 am
:lol: :lol: :lol: :lol: :lol: :lol:
oh thats funny.....
Post by Zelandeth » Tue Feb 24, 2015 6:07 pm
Let the Saab run for an hour or so, started first touch of course once the battery was charged. Also drowned the Xantia's engine bay in degreaser and gave it a hose down. At least has got rid of the worst of the gunk that has accumulated recently and the splash damage from my recent fuel filter change.
Some of the more stubborn deposits aren't going to.be so easy to shift. I miss the hot water pressure washer we used to have at the garage...could shift anything with that thing (including paint, wiring insulation, wiper blades and human skin in the hands of the untrained, unwary, half asleep or idiotic).
